JD 4B plow
georgec
07-22-2005 08:50:47
two questions: what do I need to do to get the cantaliever side wheel off. I have taken out the bolts but it only comes out so far before it stops.
The right side wheel is off but the inside cast hub is broken. Any suggestion on who might have one. I am near Akron, Ohio.
Bob Collins
07-22-2005 18:37:18
 Re: JD 4B plow in reply to georgec, 07-22-2005 08:50:47
To remove the land wheel, use a large puller or a jack pushing against the end of the axle, hook jaws or chain around hub of wheel, be careful of the spokes. Apply some pressure then thump the back side of the wheel hub using a piece of hard wood and a mall. The wheel mounts on tapered splines and will usually pop off. You need to have the hub cap off but not necessary to remove the pin through the axle. Parts are where you find them, try any local salvage yards or swap meets first, shipping is a killer.
