Fegurson 3 pt Rake ID
Bill F
07-21-2005 21:29:09
Can anyone tell me how to ID the model on a Ferguson 3 point side delivery hay rake? Thanks
Jen-Son Farms
05-26-2006 10:29:35
 Re: Fegurson 3 pt Rake ID in reply to Bill F, 07-21-2005 21:29:09
Where can I get parts for a Ferguson DE-O-20 Side Rake? Are any other parts inter changable?
Bkeepr
07-22-2005 03:57:21
Jim.UT is right. I've got one of each, the DEO-20 and DEO-25...if you post a picture, one of us can id it for you but the most obvious difference is the size. The DEO-20 swath is 7', but the rake is wider, actually doesn't seem a whole lot less than the -20...never measured it, but I'll bet it is perhaps 10' total.
Tom A
Bill F
07-22-2005 06:49:48
 Re: Fegurson 3 pt Rake ID in reply to Bkeepr, 07-22-2005 03:57:21
Thank you for both responses! I cannot locate any ID plates, but Mine is clearly not as large as the -25, so is no doubt the -20. Thanks again
Jim.UT
07-21-2005 22:20:38
It's probably a DE-O-20 or DE-O-25. I have a 25. I think the main difference between the two is the 25 is wider (about 12' wide) and I think the 20 is about 7' wide. Mine has a Ferguson ID tag riveted to the frame. Yours must be missing.
These rakes share some parts with the later MF36 and MF 25 rakes, such as teeth, teeth retainers and probably sidewheels, basket ribs, bars and bearings. I'm not 100% sure on the interchange parts but I know I swapped some parts from a MF36 onto my DE-O-25 and I also robbed some basket ribs from an MF25 and they were a direct swap.
