Using a post hole auger...
Jerry A.
07-21-2005 16:14:26
First time I've ever used a post hole auger. It cuts a nice hole, but it seems to me that an awful lot of loose dirt remains in the hole (I'm using a 12"-14" diameter bit). Any words of wisdom from you experienced guys on how not to leave so much dirt in the hole to be cleaned out by hand, or is that just the way it is?
TIA
Jerry A.
BobMo
07-22-2005 05:32:29
 Re: Using a post hole auger... in reply to Jerry A., 07-21-2005 16:14:26
Leand is correct if you want to do it right. You can stop the auger at the bottom of the hole and lift it out loaded with dirt. Get it above the hole start it and sling the dirt away from the hole. You will still have to clean out the hole. Thats the way things are. Good luck and stay away from the auger if it's running..... ....
bigjt
07-21-2005 20:14:33
Not that my experience is that great but here is a suggestion I have seen work.
Drill your hole with the engine idled down to help avoid rocks. When all the dirt is loose speed the engine up to clean the hole out.
As suggested before you need to be scraping the loose dirt away from the hole also.
JM2CW
jt
ChrisLSD
07-21-2005 19:45:50
we always scraped the dirt away at the top of the hole so a whole bunch more doesn't fall in - also at the end put the auger way down - shut off the pto - lift it all the way up and give the pto a final spin to shake off the dirt before u move
Leand
07-21-2005 19:26:52
Buy a pair of hand post hole diggers that look like a clam shell I have used a pair of these to clean out hundreds of post holes.
old
07-21-2005 16:18:57
You need to drop it in pull it out and drop it back in over and over to get most of it out. You also have to go 6-12 inches deeper then you want it so what you don't get out is at the bottom and you put the post on that.
