Dearborn loader question???
JerryW
07-21-2005 13:52:21
I have a new to me 8N with a model 19-8 Dearborn front loader. The hydraulic hose going to the pump is collapsed and twisted, and I don't know if the fluid level is where it should be. How do I check the fluid level, and what is the fix for the hose - just replace it, or is there some upgrade to do? Thanks in advance.
Illinois Boy
07-21-2005 14:15:31
 Re: Dearborn loader question??? in reply to JerryW, 07-21-2005 13:52:21
Replace the hose... the reinforcing in the rubber is probably damaged.
Check and see where your pump for the loader is powered from - probably PTO driven - may be off a belt on the engine. That's where the resevoir will be. Should be some kind of level plug or plug / cap with a dipstick on it.
Fill it until the fluid comes out the level hole or mark on the dispstick.
