So close! But not quite finished yet.
PJ
12-19-1999 16:16:40
I have my front industrial ford loader rebuilt, painted & mounted on ford 801 tractor. Now all I need is a way to hook shaft going to pump to the front of my crank. Comming from pump(in order),is a drive flange connector (2 1/4" bolt spacing) then a flex plate then another drive flange connector and then shaft (3/4" X 9 1/4" with 6 spline to crank side). My engine is 172 cid gas with a 7/8" crank bolt and four bolts for pulley spaced 2" apart and 3" from corner to corner(cross ways). Does anyone know of some bracket that will bolt to my crank and will accept the 6 spline shaft from my pump.
Or any other ideas how to connect this. Thank you guys also for all the help you have been so far with this project! God bless and merry christmass to everyone.
