Problem with Fahr two spool tedder
JHunt
07-19-2005 23:18:30
I have a Fahr two spool "Centipede" tedder. After using the tedder for a while, the spools will get out of whack with each other. If you would look across both spools from the side, one(the one not attached to the PTO) will dip down in the front. The head is rotating on the cross tube. I was wondering what holds the head from rotating on the tube. I don't see anything on the outside that could be tightend up to stop this. Also would like to know of a good source for teeth for this tedder. Thanks.
