Hydraulics
Bill59
07-19-2005 08:50:13
I have an International B414 tractor. It came with only the 3 point hitch. No power steering. The hyd.
pump is mounted on the side of the engine. The lines run from the pump to the conrol valve set up and return from the reservoir back to the pump. About 3 years ago I mounted a bucket to the tractor with lift and and tilt. The hydraulic lines now go from the pump through the control valve for the lift to the 3 point hitch set up and back to the pump. This set up has worked great.I only use the tracot to blow and move snow in the winter and ocassionally in the summer to move some top soil etc. Since the winter it has been parked and at last use every thing was working OK. Last week I went to move it and the hydraulics will not work . I have checked fluid levels and looked for leaks and every thing is OK. I took the line off from the pump and started the tractor and there is flow but I don't know how much pressure there is.I drained the reservoir and checked the filter and its OK.I;m going to put a pressure guage on the system to night and see what pressure I'm getting.
Any help with trying to trouble shoot this would be appreciated.
old
07-19-2005 09:07:43
 Re: Hydraulics in reply to Bill59, 07-19-2005 08:50:13
The by pass/preassure regulator maybe stuck. If its stuck open you will not have enough preassure to do any thing. This is just a guess but I know from the old been there done that, is could be your problem.
