fahr tedder
Brandon Johnsto
07-19-2005 08:16:19
I have a fahr tedder and one of the rims and the bearings are gone. I went to the dealer and they had no book and have never even seen that size tire and arm that the tire hooks to. The numbers that I pulled of the serial tag are Masch-Art KH4 Nni 06-251190. The rim is a bolt together and is four inch. If anybody can help me that would be great Thanks
Our Farmer
07-19-2005 14:41:18
 Re: fahr tedder in reply to Brandon Johnston, 07-19-2005 08:16:19
Was in your shoes not long ago with my Duetz-Fahr tedder. Fortunately I could salvage the wheel with some judicious welding. I think if you measure the shaft, you can find some off the shelf wheels with bearings at a farm store or out of a catalog. The shaft's a little bigger than the 5/8" most places carry. Might not be factory new, but it'll work. I made the mistake of replacing one of the tires with a turf tire off a lawn mower. Big diamond tread catches the hay and causes the rotor to wind up tight. Ribbed tires is the way to go.
Ken Macfarlane
07-19-2005 11:17:48
We use a Deutz Fahr KH-4 tedder and it is an old kuhn model rebadged. It is a 4 rotor with the cruddy cross and drive tang for the outside rotors and they swing rearwards for travel.
Ken Macfarlane
07-19-2005 11:17:37
