Right colors New Holland farm wagon ...
larry o
12-18-1999 08:44:33
I bought a New Holland farm wagon that appears to have been built in 1950's or 1960's. What were the original colors of the frame , wheels, and bed? It is 7 1/2' wide and 12' long. The bed has metal strips between the wood flooring and all around the outside (and has stake pocits). Thanks
larry
Tim(nj)
12-19-1999 16:35:28
 Re: Right colors New Holland farm wagon ... in reply to larry o, 12-18-1999 08:44:33
Does it have a single center reach pole, or two channel-iron reaches down each side of the gear? It makes a difference in painting it. The single center pole version is all red, with a yellow tongue and wheels. The double channel gear has a yellow tongue, yellow wheels, and both channel reaches yellow. The bolsters and axles are red. The bed may not be factory, but I would thing the steel parts of it would also have been red and the wood floor was probably left unfinished.
larry o
12-20-1999 09:12:40
 Re: Re: Right colors New Holland farm wagon ... in reply to Tim(nj), 12-19-1999 16:35:28
Thanks, it has a single steel center pole and two 4X8X12 wood members setting on beneath steel crossmembers. I don't know if the bed is original.
I called a local sawmill and can get oak replacement wood (2X8X12 flooring and 4X7X12 main mebers)for around $165.
thanks again
