NH 55 rake bearings
Tom 8N396936
07-18-2005 19:00:05
I have been looking in the archives and have not found an answer to my question. I have NH 55 that one bar has bearings that are shot. Got the bar off OK but how do I get the bearings out? Are these pressed in? Any tips to getting these out would be helpful.
Thanks
tom
CJ-maybe
07-19-2005 15:15:00
 Re: NH 55 rake bearings in reply to Tom 8N396936, 07-18-2005 19:00:05
Run a weld bead on the face of the race ,it'll come right out.A modified prybar,loosen the spiders,sweat and cuss some,they'll go in.
txgrn
07-19-2005 08:19:03
If you are talking about side discharge, parallel bar rakes I have a much better idea.
Drill a hole in the back of the casting (bar is attached to the front). Tap it and install a zerk. Squirt till it comes out. Once you get it full, it just takes a couple of pumps to top it off. Much much easier than removing those bars.
Mark
txgrn
07-19-2005 08:18:56
Mark
txgrn
07-19-2005 08:18:35
Mark
Kelly C
07-19-2005 04:26:18
Need to make a puller. Use a pipe the width of the bearing cup. A peice of flat steel biger than the pipe with a hole in it.
Place the pipe over the bearing, put the flat steel on top. Screw the bolt back onto the bearing and it will pull it out.
Bearings should run about $45 each from NH dealer.
Getting those bars back on is a real job.
Tine bar bearings need to be removed to grease them. The manual say once every other hay season.
You need to remove the tine bars to do this.
Remove A tine bar as follows:
#1 Loosen the mounting bolts to the right spindle assembly.
#2 Loosen the bearing stud at each end of the tine bar which is to be removed.
#3 Remove nuts from each end of the tine bar and remove it from the reel.
Note: two consecutive reel bars and the right spindle must be loosened in order to remove a single bar from the reel. Damage may result if not done this way.
Tine bar bearings:
#4 Take the dust cap off the bearing housing and remove the snap ring. Remove the bearing from the bearing housing by placing the nut on the threaded end of the bearing stud and tapping aganst the nut.In some cases it may be necessary to place some spacers against the shoulder of the bearing housing and pull the bearing out by tighting the nut against the spacer this pulls the bearing out.
Installing the tine bar bearing:
#1 clean all parts toughly.
#2Pack the tine bar bearing with grease. Fill the cavity of the bearing housing this would be behind the bearing when installed. Do not fill completely.
#3 tap bearing into position. Make sure the seal is seated against the shoulder of the housing and install the snap ring.
#4 fill the cavity on the outer side of the bearing with grease. The grease should completely fill this area to keep area clean. Reinstall the dust cap
#5 reinstall the tine bar. It is very important that the nuts on the left end of the tine bars be made very tight (150lbs-ft torque)
Hope this helps
paul
07-18-2005 20:08:42
One fell out on it's own, the other one the torch got out.
Not sure what is propper.....
Assuming yours were kinda loose, the bar comes out easy - be prepared for a _very_ difficult re-install if you haven't done this before....
--->Paul
---->Paul
Tom 8N396936
07-19-2005 14:17:34
 Re: NH 55 rake bearings in reply to paul, 07-18-2005 20:08:42
Thanks all. Yea it looks like its going to be a fight- one has the thread stripped and one was removed with the "black and green wrench".
Well, if we don't start we'll never finish.
again- thanks
