weak post hole digger
Denny (WI)
07-16-2005 09:14:16
I'm redoing some fence work around the house and my single hand held digger won't digg into clay! it works fine up untill then. Can I change the angle on the bottom of the augger? Any other ideas? Thanks Den
Our Farmer
07-16-2005 12:22:16
 Re: weak post hole digger in reply to Denny (WI), 07-16-2005 09:14:16
Got a welder? On my 3 pt. auger, I welded some 3/16 flat plate to the wings on the bottom of the auger to strengthen them, then cut some teeth out of some 1/4"x1.5" flat bar stock I had lying around and welded those on. Put 3 on either side. Worked great, can pretty much set a post in anything short of granite now. Just leave enough point extending to hold the auger straight. If you don't have a welder, a shop would probably do the job for $50.
