Fixed a problem with my homebuilt rake.
Loren
07-15-2005 21:55:00
If anyone remembers I took the Sitrex apart last spring and made it into a trailer rig with hydraulic lift, adjustable frame height, adjustable attack angle for the pinwheels and adjustable tow width/tracking. Also built in a problem that I've been figuring how to rememdy. Anything over a real fast walking speed made the caster wheel go into a death shimmy. That meant disassembly and reassembly on every move. The caster side of the rake is pretty light whereas the hitch/other side is more than a couple hundred pounds. The other day before going to rake I took a chance and shoved and 2&3/4" x 1&1/2" x 24" flatbar inside the frame and tied a 5' chunk of railroad rail on with it. Came home tonight at one click under max in 300U high gear and not a single quake was seen. Now I need to figure how to permanently mount a bunch of weight there. :>) Loren.
