488 ng haybine
mgm
07-15-2005 05:28:53
o not own a owners manuel therefore i need to know how to replace the bearing on the outside edge of the lower roller. There is a plate and a cap with a hex does this need to be removed? Is this a difficult job? Thx
Charles Mo
07-15-2005 06:00:34
 Re: 488 ng haybine in reply to mgm, 07-15-2005 05:28:53
Remove the locking collar by loosening the set screw and placing a punch in the dimple hole on the collar and turning it the opposite way the roller turns. Remove the four bolts holding the outside bearing carrier. To remove the old bearing I had to "shave" the side of it with a cutting torch until it was thin enough to break off the shaft. Hope this helps.
