Hay Bale Spraying
Vince H
07-14-2005 13:16:43
I was looking around one of the ag centers for equipment last night. They were already closed so no one available to ask questions. There was a JD baler with a plastic tank on top of it. I am guessing it would hold about 50 gallons. It had a hose that ran down and onto the pick up guard. had 4 small spray heads facing into the pickup chamber. For the life of me I couldn't figure out why you would want to get your cured hay wet again. What would that be used to spray onto the hay?
Iowa Jim
07-14-2005 13:28:36
 Re: Hay Bale Spraying in reply to Vince H, 07-14-2005 13:16:43
That is a preservative applicator. Two type os preservatives are used on baled hay: Organic Acid mixtures, and Bacterial Mixes.
Jim
paul
07-14-2005 21:57:54
 Re: Hay Bale Spraying in reply to Iowa Jim, 07-14-2005 13:28:36
It allows you to bale the hay what - 5 points higher moisture?
--->Paul
kybailer
07-15-2005 04:11:34
 Re: Hay Bale Spraying in reply to paul, 07-14-2005 21:57:54
I just picked up a sprayer kit yesterday for alfalfa and best I can tell you want to shoot for a 22%-25% moisture on squares.It keeps the molds from growing.I'm using a buffered propionic acid that is not supposed to rust the bailer up.In my figures it will cost about $.30 a bail.
Hayman
07-17-2005 16:09:56
 Re: Hay Bale Spraying in reply to kybailer, 07-15-2005 04:11:34
What kind of bales does 22% alfalfa make after it sits in a stack for a month??
Hayman
07-17-2005 16:05:53
