Deere 530 baler
Ia Steve
07-14-2005 07:32:51
Hi
Bought this used baler and have been reasonably happy with it. Made approx. 75 first cutting bales that while they looked good I felt they could have been a little tighter.
So 2nd cutting I increased the tension, gauge still safely in the green (if its accurate) and made 50 bales that were just what I wanted nice and tight but now to the ?? I had 2 pins break in belt splices. Am I causing this by to much tension ? Normal wear and tear? or should I have replaced the pins at start of season as a maintanence item ?
By the way I am not sressing things by pushing the envelope on diameter, am about 6" below full sized.
Thanks Steve
Tx Jim
07-15-2005 04:56:09
 Re: Deere 530 baler in reply to Ia Steve, 07-14-2005 07:32:51
Steve,it's best to replace lacing pins(cables) every 1000/2000 bales depending on type soil.They are a little difficult to remove when in pieces.If you ever have to relace any belts try the newer riveted laces as I think they last alot longer and pins are easier to change.Tx Jim
Hay Dr
07-14-2005 08:41:41
Do not use the pins on the JD Belts use the plastic coated stainless steel cable. The cable distributes any shock load to all the hooks better than a pin does. If you use the pins you will have edge fastener problems.
centralilbaler
07-14-2005 16:35:04
 Re: Deere 530 baler in reply to Hay Dr, 07-14-2005 08:41:41
i agree HayDr. those coated pins are definately alot better than fixing belts all the time!!
