Twisted PTO Shaft...
Cam50
07-14-2005 04:15:40
I just plugged my N.H.469 haybine and actually twisted the shaft in two just behind the support bracket on the tongue. I assume the slip clutch didn"t slip...? Does anyone know of a source for a used shaft?
Nebraska Cowman
07-14-2005 15:10:49
 Re: Twisted PTO Shaft... in reply to Cam50, 07-14-2005 04:15:40
I assume you twisted the tube half? that is just a welded assembly. grind off the yoke and the other end is just a short piece a foot or so welded in too. You should be able to buy tubing anywhere.
