Square Baler Plunger Spear for Vent Hole
FrenzFarms
07-13-2005 13:33:24
I was curious if anybody could tell me their experiences with these aftermarket spears you install on square baler plunger that form a vent hole through the center of each flake for drying. Additionally, where can they be purchased from, average price, and ease of installation?
JMS/MN
07-14-2005 10:19:26
 Re: Square Baler Plunger Spear for Vent Hole in reply to FrenzFarms, 07-13-2005 13:33:24
They are easy to make- use solid shaft, 1 1/2 or 2 inches diameter, about 5-6 inches long. Mount it to a square plate about 3/8 or 1/2 inch thick- drill the plate so you can weld on both sides.Bolt the plate to the plunger head.
JMS/MN
07-14-2005 10:21:03
 Re: Square Baler Plunger Spear for Vent Hole in reply to JMS/MN, 07-14-2005 10:19:26
Forgot this- round off one end of the shaft- torch and grinder or turning lathe would work.
RickB
07-13-2005 18:27:15
If you bale wet hay and don't treat it with chemicals or dry it with heat and forced air, it will mold whether the bale has a hole in it or not. I can't imagine it helps in filling the far side of the chamber.
