Yuppies and the Price
Allan in NE
07-13-2005 07:23:07
Hi All,
Talk about the yuppies drivin' up the price of old machinery!
I've been shoppin' fer an old 14' packer since forever it seems. Dealers are getting between $2500 and $5000 for the darned old worn out things that nobody uses anymore.
When I asked why so high on the price and were they coming back in fashion, the dealer tells me no, the horsey people like to use 'em on their ridin' arenas and that he just cannot keep the silly things in stock.
And I'm not goin' to get a bigger tractor to tug a 15 or 16 footer. :>(
Allan
txgrn
07-13-2005 13:59:39
 Re: Yuppies and the Price in reply to Allan in NE, 07-13-2005 07:23:07
Shucks Allan I thought you read my thread about the JD 510 baler that a guy said was only worth $500 (cause that was apparently all he could get) but he wasn't in the Dallas metroplex where it would bring $3500..... ..... ....cause of the yuppies. Grin
Mark
Brian 1
07-13-2005 12:55:53
People are looking for them to use on deer food plots. Lots of clover, trefoil, turnips, and other small seed being planted for deer.
SteveKS
07-13-2005 12:34:54
Hey Allan,
Doesn't that new drill have press wheels on it? Here's a link to some research that showed press wheels being more effective than a cultipacker (see page 21). It was pretty close though. :)
Allan in NE
07-13-2005 12:44:02
 Re: Yuppies and the Price in reply to SteveKS, 07-13-2005 12:34:54
Hi Steve,
Yeah, the drill has press wheels; that's not what I need it for. I gotta plow up 115 acres of grass.
Packers do such a sweet job on plowed ground.
Allan
ShepherdBill
07-13-2005 11:04:24
Allan, I thought you were a yuppie. Maybe your wife has contact with some horsepeople that would let you borrow their packer.
Sid
07-13-2005 21:23:30
 Re: Yuppies and the Price in reply to ShepherdBill, 07-13-2005 11:04:24
Allen ain't no yuppy. Yuppies is young.
Allan in NE
07-13-2005 11:10:10
Geeze!
That was a swat from out of nowhere! :>)
Allan
txgrn
07-13-2005 14:17:20
 Re: Yuppies and the Price in reply to Allan in NE, 07-13-2005 11:10:10
What's a packer anyway?
Thought you were a hayman.....with some cows that stays away from corn. OOOOh, didn't mean to open an old wound, Grin.
Mark
caseyc
07-13-2005 10:47:15
are you talking about the little brillion type packers? one disc is notched, one isn"t and so on? if so them darn things are a dime a dozen around here. i"ll try and get a pic of mine in the next day or so unless you come up with one sooner.
casey
Allan in NE
07-13-2005 11:08:52
 Re: Yuppies and the Price in reply to caseyc, 07-13-2005 10:47:15
Hi Casey,
Well kinda. Some have crowfeet and a smooth wheel combination with a couple of rows spring tooths.
Most people call 'em cultipackers, I think. Since I'm a "plow type" guy, I've got to find one somewhere.
How's the 7 coming along?
Allan
caseyc
07-13-2005 12:06:08
 Re: Yuppies and the Price in reply to Allan in NE, 07-13-2005 11:08:52
that sounds like mine and every other one floating around the country side here. they can be had for less than $100 if your at the right sale. mines a 8' with two 3' detachable "wings" for a 14' total width. if you really need one i know i can round one up.
the 766 should be running by sat night. number two piston was melted, the rings all broke up and slid up the piston and are now embedded into the top of the piston and head. the crank is fine. the bearings had alittle wear but were okay. i sent the pump and injectors off and they had to get a new pump cause mine was "exploded" and not repairable. i knew it had a miss now and then. guess #2 got just alittle too much fuel at once! the sleeves had alittle cavitation starting, not too bad though. she's getting a complete minus the rear crank seal. i didn't split it. it's not leaking so i hope i can snake those mains out without damaging it. the case-ih boys say no problem, so we'll see. one of my buddies actually works for ih so he's gonna come up on friday and "supervise" assembly. keep your fingers crossed for me.
you should have made me an offer sooner cause she just got more expensive 8>)!!!!!
casey
R. John Johnson
07-13-2005 07:42:02
Mornin' Allan
Wish I had a digital camera to get a picture of the packers used up here. The land up here is very stoney and it is just not practical to try to pick all the fist to head size rocks. The packers are shop built, 4 to 8 feet in diameter and 10 to 14 feet wide. My cousins is about 8 feet in diameter and to the best of his knowledge the drum is half inch thick steel. If putting in a ceral crop for silage the seed is broadcast on top, lightly harrowed then packed. The packer has a large enough surface area that is does not compact the soil too much. However, when the packer hits a stone sitting above the soil all the weight is concentrated on that stone pushing it flush with the soil. The field is smooth and there are no rocks sticking up to damage other equipment later.
John
KRUSS
07-13-2005 10:44:15
 Re: Yuppies and the Price in reply to R. John Johnson, 07-13-2005 07:42:02
Those drum type packers mentioned are referred to as land rollers. I have used one many times to roll peas so the small stones and lumps of dirt are pushed down. We used a 32 to 36 ft one and a 2096 pulled it easily at 7 mph.
Illinois Boy
07-13-2005 11:47:35
 Re: Yuppies and the Price in reply to KRUSS, 07-13-2005 10:44:15
There's lots-o-packers around here - more than in Green Bay...
txgrn
07-13-2005 14:32:36
 Re: Yuppies and the Price in reply to Illinois Boy, 07-13-2005 11:47:35
Cute.
