ODD WAGON WHEEL RIMS
pop
07-12-2005 11:52:46
ANYBODY EVER SEEN A SOLID WAGON WHEEL RIM IE NO CENTER HOLE LIKE ON MODERN CARS AND TRUCKS[HUB CAP IS PART OF RIM] . TAG SAY MADE IN QUINCY ILL. REST NOT READABLE . GOING TO RESTORE FOR HAY RIDES ECT. WOULD LIKE TO KNOW WHAT COLOR TO PAINT IT, ITS RED NOW BUT HAS BEEN REPAINTED ANY INFO WOULD BE USE FULL
Leroy
07-12-2005 18:02:07
 Re: ODD WAGON WHEEL RIMS in reply to pop, 07-12-2005 11:52:46
Coop had 5 lugs and a wagon built in Troy, Ohio had 6 lugs and possibly others, don't know who made the rims.
Don-Wi
07-12-2005 15:46:41
We've got 2 wagons like that w/ the bubble over the center for the hub. Bolt pattern is 6- 6.5" (a standard 6-6 bolt rim WILL NOT fit) the rims on ours are 16" x about 6" or so, never actually measured. They are more common than you think, I've seen a few other wagons in the area with the same style. Unfortunatly one of those wagons jack knived going down a steep hill loaded w/ hay on the lane from the neighbor's feild, so it's sitting in the weeds. Ours is a Better Bilt runnning gear, and we've got 5 BB's total, all different size hubs, and the others all use a more common rim, 5," 5 1/4" and 5 1/2" 5 bolt patterns
Donovan from Wisconsin
sam in mo
07-12-2005 12:44:07
I think it is from the electric wheel co.dont know the color. they made wheels for several different co's from what I understand.Let us know if you find out for sure.
Tim(nj)
07-12-2005 18:15:53
 Re: ODD WAGON WHEEL RIMS in reply to sam in mo, 07-12-2005 12:44:07
Electric Wheel Company was in Quincy. Could be they built the running gears for CO-OP. EWC made running gears for Oliver, Sears (David Bradley), Ford (Dearborn), Allis-Chalmers, and several others over the years.
Johnbob
07-12-2005 15:33:46
Coop made wagons with that type of wheel.If I remember right they were painted orange.That was in the late 40,s and early 50,s.
Johnbob
07-12-2005 15:31:20
