Wheel Weights Wanted
Vern
12-16-1999 07:51:34
Does any one have a set of rear wheel weights that they would part with for an 816-S Gravely Rider? Also does any one have a set of the weights and the bracket that hang on the front of the tractor for rear tilling? Thanks
Tom S.
12-16-1999 11:50:20
 Re: Wheel Weights Wanted in reply to Vern, 12-16-1999 07:51:34
I don't know much about your tractor, but if you decide to fabricate some wheel weight, consider finding some old truck or car brake drums that closley fit the inside diameter of your wheels. Spot weld some long bolts from the inside out to use as mounting studs to the rims, then lay them flat open side up, and fill them with bits of old bolts and small steel scraps mixed in concrete you pour in. Smooth the face with a trowel and paint when dry. Looks just like steel. Tom S.
