JD no.9
holcombwa
07-11-2005 21:28:10
Ok, up until 6 years ago our mowing machine was a 1930 something david bradley horse drawn. So, never had to deal with PTO's until very recently. Have a JD#9 sickle bar I've been using with our case VAO. The case is sick so was going to hook it onto the "new" ferguson TEA20. Got everything lined up and went to disconnect the PTO and hook up the brand new one I bought for the Ferguson and... the JD mower has a special spline on the mower end of the PTO. Of course, the PTO that came with the mower had to be cut down to fit the case, so..... it is now way too short for the fergy. Is there a method for taking the spline off the JD PTO shaft and mounting it on the new PTO shaft? If not, is there an adapter that will convert the JD mower spline to standard 1 3/8" PTO? Sorry to ask what are probably really stupid questions, but never had to deal with the problem before, and it's finally suppose to quit raining so we can make some hay. Thanks in advance.
Stan
Jim.UT
07-12-2005 10:29:19
 Re: JD no.9 in reply to holcombwa, 07-11-2005 21:28:10
I have a JD #9 but I've never had to remove the driveshaft from the mower so I didn't even know it had different splines. I'll take a stab at this anyway:
I believe that you will need to remove the female coupling from the mower end of your new driveshaft and replace it with one that matches the mower's shaft. This will mean removing the u-joint from that end. Look at it carfully. Some have internal snap ring and some have external snap rings.
Count up the number of splines on the mower shaft and measure it's diameter. Take the part you removed from the mower end of the new driveshaft back to the store where you got it and tell them you need a part just like that only with the correct number of splines and correct diameter. Put your driveshaft back together with the new part that fits and you should be ready to go.
Let us know how it turns out.
