Krone Mower
MITCHP
07-11-2005 12:49:57
Anybody had any experience with a Krone Disc Mower? My uncle was thinking about getting one and didn't know much about them.
KEH
07-11-2005 14:18:12
 Re: Krone Mower in reply to MITCHP, 07-11-2005 12:49:57
MITCHP, I live near Gene H. that HayDR mentioned. He usually has new and used ones in stock. The Krone is a gear bed mower, gears run in oil. It dosen't have belts, uses shafts. In park position, it stands by itself, no parking stand. To hold the blade in transport position, a valve is closed in the hydraulic line. Other makes like the Agco line uses the same system which I don't like because if I understand it correctly, its holding power depends on the O rings in the hyd. cylinder to hold it up. Maybe HayDR can comment on this. Like HayDR said, it is a premium, well made mower.
KEH
Hay DR
07-11-2005 16:14:24
 Re: Krone Mower in reply to KEH, 07-11-2005 14:18:12
In this day in time with the litigious society we live in Krone would have changed it long ago if there was just one accident due to a failure in there system. I may like another system better but Krones works fine. I happen to like shaft drive cutterbar mowers better because the shaft drive mowers are lighter on the 3 point and need 20% less HP to operate. The Krone mowers are well made and do give a good finish product cut.
Hay DR
07-11-2005 13:45:02
Krone is a premium disc mower. They have a strong presence in Europe. One of their large dealer is Gene Holliday in Laurens,SC. 864-682-3931
Hay DR
07-11-2005 13:36:27
