drum mower
John King
07-11-2005 12:02:02
I bought a
I recently purchased a Fahr KM22 drum mower. It has a small vented fill cap on top of an oil reservoir, but I don't have a clue as to what the level should be. I can't find any check plug or other indicators. Do I fill it to the top? Does it use 90 wt. gear oil or ? The guy I bought it from was of no help, as it had been his fathers.
Thanks for any help you can give me on this.
Jimmy King
07-12-2005 02:52:25
 Re: drum mower in reply to John King, 07-11-2005 12:02:02
I have just been kidding my son about puttting this post on here, He is John King also
wjw_farm
07-24-2005 17:11:42
 Re: drum mower in reply to Jimmy King, 07-12-2005 02:52:25
hi, i got a greeland geldrop drum mower and need parts for it. Does anyone know where i can get parts. it is a model 220 two drums.
thanks bill
Jimmy King
07-12-2005 02:51:19
I have just been kidding my som about puttting this post on here, He is John King also
Hay DR
07-11-2005 13:10:39
I would recommend EP"00" Grease and only 1/3-1/2 full.
John King
07-12-2005 11:24:46
 Re: drum mower in reply to Hay DR, 07-11-2005 13:10:39
I don't really know what EP"00" grease is, but this tank runs between the drums and contains the shaft that runs them. It is about half full of what looks like gear oil, and looks like it would hold several gallons.
DR HAY
07-12-2005 20:43:21
 Re: drum mower in reply to John King, 07-12-2005 11:24:46
The original lubricant was the equivalent of EP"00". This is a fluid grease that flows like molasses. If you use gear oil you likely will have seal problems.
John King
07-13-2005 23:44:04
 Re: drum mower in reply to DR HAY, 07-12-2005 20:43:21
Can't see a drain plug on it. The stuff thats in there seems thinner than molassas, but could be the right thing. Could I just add EP"00" to it when it gets low or would that cause problems. Mowed about 6 acres of thick down stuff with it today and man does it cut. I would like to see what it could do when it was new.
