John Deere 336 problem and possible solution
Ken Macfarlane
07-11-2005 11:27:06
Our JD 336 is great with one glaring exception, all the bales come out short on the side away from the throat. Not enough to banana but enough to lose strings frequently when handled the 2nd or 3rd time.
I tried every setting on the packer forks to no avail.
I looked inside, both hay dogs present and working.
One set of resistors installed as a matching pair.
Surfaces evenly rusty / polished.
Knots look identical
Tried cranking down the bale tension on the long side to no avail. Tried REALLY cranking it, no change.
Got to looking at the chute and the chains as ours is set to drop on the ground. Instead of a carriage bolt three are hex head. 2 of those are on the side that is always shorter. One of those 2 is loose and double nutted so when bales push past they cock it sideways.
My theory is that bolt is increasing the bale density on that side causing my troubles! So, off to find a few carriage bolts and some dry hay to bale!
msb
07-11-2005 18:04:40
 Re: John Deere 336 problem and possible solution in reply to Ken Macfarlane, 07-11-2005 11:27:06
Sounds like your windrows are too small or your ground speed is too slow.A properly fed 336 should make 11 to 13 strokes per bale.I counted mine baling straw today.It was averaging 12 strokes per bale and that told me I was running it exactly the way the baler was designed to run.A 336 should also run at 80 strokes per minute.
Dave Sherburne,NY
07-11-2005 14:52:32
Just finished 3 loads with a 336 nice tight bales no banana bales I don"t worry about which side the hay goes in on. Just load it full , I have to push in the clutch and let the baler catch up
sometimes . I keep telling the rake man to double
the windrows. My problem is that stupid kicker.
Tx Jim
07-11-2005 14:07:48
Ken.I think hay dogs are not problem but a JD 336 has 3 hay dogs.Have you checked timing of feeder fingers? When feeding hay into pick-up do you feed into extreme RH side of pick-up(very important)?It's a wives tale that cranking down on one side of tensioners will correct banana shaped bales(ain't happening)!!! Tx Jim
Ken Macfarlane
07-11-2005 18:08:50
 Re: John Deere 336 problem and possible solution in reply to Tx Jim, 07-11-2005 14:07:48
Haven't playing with timimg, only the throw on the fork.
Have fed both sides of pickup and various size windrow. Doesn't matter, always a consistant bale with the same slight banana.
I'm curious about the dogs, thought I counted a pair. But 3 would make more sense.
Ken
Tx Jim
07-12-2005 03:49:22
 Re: John Deere 336 problem and possible solution in reply to Ken Macfarlane, 07-11-2005 18:08:50
Ken,there's two dogs on top and one dog under bale case if I remember correctly.On feeder finger timing with plungerhead on compression stroke with face centered in frt. finger slot check measurement.I think it's 10/11 inches.JD states that if you feed baler on extreme RH side it will give auger time to distribute hay properly.Tx Jim
Ken Macfarlane
07-12-2005 05:47:27
 Re: John Deere 336 problem and possible solution in reply to Tx Jim, 07-12-2005 03:49:22
Thanks! I'll check the fork timing.
Re the windrow, our single raked windows (9 ft rake) fill the entire pickup, the whole width and up to the precompression / control tines.
On thinner stuff I've played with which side and it doesn't seem to matter. It always comes out the same. Feeding from the far side only seems to encourage auger wrapping from getting outside the end of the auger.
The only stuff it doesn't like is when the windrow is so thick there are only 4 flakes in a 36" bale. Horse people hate that too so I don't have to worry much!
Tx Jim
07-12-2005 13:36:24
 Flakes 9 in. thick? 4 flakes/36 in.bale? in reply to Ken Macfarlane, 07-12-2005 05:47:27
Ken,I'm curious as to how many bales this hay is making per acre and what bales weight. Thanks,Tx Jim
Ken Macfarlane
07-13-2005 06:40:34
 Re: Flakes 9 in. thick? 4 flakes/36 in.bale? in reply to Tx Jim, 07-12-2005 13:36:24
Jim,
First and article I found after writing:
Link
Next the post I wrote first:
Around here by the river valley, if you miss the dry spell in June and cut late, the hay is very thick. A windrow raked from about 14 ft of tedded out hay has to be baled in first gear and you have to ride the clutch. Sometimes when you hit a big chunk and have to clutch, a bale will come out and plop on top of the last bale to come out.
Bale weight is around 40-50 lb normally. Can be up to 60 lb when pushing the moisture levels when rain is coming. At this weight and 36" the double raked windrows can pop bales out like every 10-15 feet. 100 bales an acre sounds familiar.
That would be 2 - 2.5 tons per acre, similar to what irrigated guys get isn't it? Does alfalfa pack tighter or something? We sell our hay to horse people, they don't like heavy bales and if the slightest bit damp the hay will mold or heat and lose protein in the really tight bales.
Maybe the species of grasses are different? There are some fine/thin grasses here, I think called orchard grass in the US that make really dense bales. It isn't usually baled and only seems to flourish in pasture.
Our land is unirigated, unfertilized, and unlimed, was seeded about 10 years ago, and still produces about 100 bales per acre when cut late.
If we fertilized and limed and reseeded we could get 100 bales/acre in June and 50 / acre again in August.
After being out west this spring I can see why this seems weird, our pasture land likely produces as much grass as some of the hay field there.
On the flip side, it rains all the darn time and is extremely humid. We have 14 hrs of daylight most of the summer too. Ideal grass growing conditions, extremely poor hay harvest conditions.
So yes, if you try and hurry in big windrows here the baler will gobble up hay and stuff 6", 9" etc flakes into the bales.
I suspect adjusting the pickup speed would help stop this but we try to stick to single raked windrows.
Most places in the east are like this, we are bit more so due to a big river next to us and good soil.
Ken Macfarlane
07-13-2005 06:36:51
Jim,
