Woods twin cadet #121 Brush Hog Mower
Phil/PA
07-11-2005 10:30:50
Is anyone familiar with a Woods twin cadet #121 mower. I am looking for a brushhog mower and I"m familiar with brand names but not model numbers. How old is the mower, any particular problems with this model in general, is it pretty heavy duty. There is one in the paper I might look at but I don"t want to go blind and I"ve searched and can"t find too much info. What is a decent price for one. The one advertised is 10 ft, it is for $1,800 and it comes with a cylinder and a chain kit. When I look at it is there anything in particular I should check? Thanks.
Jerry Pestel
07-23-2005 08:27:10
 Re: Woods twin cadet #121 Brush Hog Mower in reply to Phil/PA, 07-11-2005 10:30:50
I HAVE ONE IT'S A GREAT MOWER WILL CUT DOWN FROM 2 INCHES TO 12 INCHES. IT HAS 2 BLADES. THIS UNIT IS VERY HEAVY DUTY AND MAKE SURE YOU HAVE ENOUGH TRACTOR TO PULL IT. THE PRICE OF $1800 IS EXCELLENT. THE ONLY THINGS I WOULD CHECK FOR IS A CASE OF SEVERE RUST WHICH I DOUBT YOU WILL ENCOUNTER. MAKE SURE THE CYLINDER WORKS. CHECK THE BLADES UNDENEATH, THEY MAY NEED TO BE SHARPENED OR REPLACED . ALSO CHECK THE SEALS TO MAKE SURE THEY HAVE OIL IN THEM. IF THERE IS NO OIL MAKE SURE AND KEEP THEM FILLED WITH A GOOD QUALITY GREASE.
Jerry Pestel
07-23-2005 08:21:20
Scott KY
07-12-2005 04:13:17
They are a good mower. Make sure the gearbox seals under the mower aren't leaking. That was a common problem on them, especially the early models. Price sounds fair if it doesn't need any repair. That model was built from the early 80s through last year.
Jay B
07-28-2005 10:52:17
 Re: Woods twin cadet #121 Brush Hog Mower in reply to Scott KY, 07-12-2005 04:13:17
I have a 6 foot Cadet Woods Brush Hog. The labels are gone. What type of oil/grease should I use in the gearbox? Thanks
Daniel Koch
07-29-2005 04:41:58
 Re: Woods twin cadet #121 Brush Hog Mower in reply to Jay B, 07-28-2005 10:52:17
I am looking for a brush hog mower with the deck at about 60-72". I just wanted to get some prices on some new or used. Can you help me out.
