melting plastic twine
jeffrey c
07-11-2005 09:18:19
i have a nh 68 with a 53as kicker. I never have a problem with knots. but i am getting more broken bales because the plastic twine is melted in half. so i am suspecting something with the kicker. any ideas? if i switch to the rope type twine, do you think this would help?
jimont
07-11-2005 15:10:19
 Re: melting plastic twine in reply to jeffrey c, 07-11-2005 09:18:19
Rick's right --- bales too long !! I found anything less than 36" would work ok. BTW , you'll still get the odd burn-through even then , due to lack of a charge of hay at the end of a row for example.
RickB
07-11-2005 13:44:36
Your bales are too long. The thrower is trying to suck the bales out from inbetween the tension rails in the chamber.
jeffrey c
07-12-2005 11:30:43
 Re: melting plastic twine in reply to RickB, 07-11-2005 13:44:36
well i checked the bale length the average was about 32" I do remeber a few wild long ones. I guess they pushed the one in front of it just enough into the kicker to melt the string.
would the other kind of twine hold up to this better?
i dont even think they had plastic twine when this kicker was made
or how do i keep it from making those long bales?
