IH sickle mower
Scott Kilmer
07-09-2005 17:25:20
I am just getting into Farmall tractor restoration, and recently came across an old IH sickle mower that I am going to restore. the bar is only 53" long and it looks like it should be able to be belly mounted under my Cub. It has the shaft that runs to the back of the tractor with a pulley for a belt hook-up. Any suggestions on where to look for a model number and find out more about the mower?
Thanks,
Hugh MacKay
07-09-2005 17:45:14
 Re: IH sickle mower in reply to Scott Kilmer, 07-09-2005 17:25:20
Scott: Those mowers were designed for Cub and Super A. There are some differences between the two. The mount where it attaches under torque tube is much wider for SA. They also turn different directions as Cub pto turn opposite direction to most tractor pto's. The problem here is the front hub on that drive shaft. It is threaded on, thus mowers are not interchangable from Cub to SA or vice versa.
The model number for the Super A versions is A-22. I think, but not certain Cub version is called Cub-22. The cutter bars are the same
