Trip spring for a Farmall blade plow
Paul F. Johnson
12-15-1999 06:14:47
I need a trip spring for Model 54 Farmall front (or belly) plow (fits the Cub). The spring measures 2-3/4" diam. x 10" long with 1/4" coil thickness. It is a compression spring and is the larger of the two springs on the plow.
Does anyone know a source for springs of this type? I have exhausted the standard snowplow manufacturers. Case/IH sells a new spring for $130! I'd like to pay less.
tbrake
12-16-1999 17:05:40
 Re: Trip spring for a Farmall blade plow in reply to Paul F. Johnson, 12-15-1999 06:14:47
I'm in the process of modifing a cub blade to work on my Super A. I'm going to use the rear springs from a motorcycle shock absorber. I don't know how it will work but we'll find out.
Mike
12-16-1999 03:58:17
Paul,
I know the exact spring your talking about. Have you tried any of the tractor salvage yards? Try
Bates Corp. or Mike's Tractor Parts. Good Luck
finding one.
Mike
Paul F. Johnson
12-16-1999 12:31:51
 Re: Re: Trip spring for a Farmall blade plow in reply to Mike, 12-16-1999 03:58:17
Mike,
Thanks for the advice. Since I posted, I found a nearby Cub dealer who has ordered a new spring from a "discontinued parts warehouse." If it is the right spring (it better be, I am paying for it, regardless), I'll try to find out his source and I'll post it.
Earier today I heated my badly rusted, bent spring to 870C and furnace cooled it through the annealing temperature, dull red, then water quenched. The spring straightened as I hoped (I put spacers between coils to straighten the bent spring before heating), but it is now dead soft; it can be bent by hand. I am trying to find a heat treatment that will harden and toughen the spring.
I'll let the list know.
-Paul
