New Holland 255 Rake/Tedder
Shane Newvine
07-06-2005 11:42:59
I need to adjust the backlash in the Drive gears in the main gear box. Anyone have a sevice manual? OR can give me some advice?
Thanks
Steve from New Holland
07-07-2005 04:18:07
 Re: New Holland 255 Rake/Tedder in reply to Shane Newvine, 07-06-2005 11:42:59
Shane, I'm not quite sure what backlash you want to adjust. There is no main gearbox. The PTO goes right into the right hand rotor assembly. There are shims on these gears, but they are not easy to work on. I've never had an issue with these gears. However, I'm wondering if you have too much "backlash" between the two rotors? That is an all together different problem and would have nothing to do with the bevel gears. Let me know. If so, I will try to give you some pointers concerning that issue. Steve
