What is this and what does it do?
Douglas J. Roje
07-05-2005 20:02:28
It came with my 52 8n.
third party image
Kevin in OK
07-06-2005 07:50:25
 Re: What is this and what does it do? in reply to Douglas J. Rojek, 07-05-2005 20:02:28
That is a flail mower. As others have said, there is a single shaft in the center which rotates. Using centrifugal force it forces chains to stick out from it perpindicular to the shaft. Small knives are connected to the chains which cut the grass. It is much like a reel mower except for the fact you can run over stuff and not break anything due to the chains instead of blades.
We use a Befco flail mower at our pecan grove, really a tough implement. It will cut 6 foot Johnson grass if you take half a bite. I don't like to cut that high stuff though, can't see anything 3 feet in front of you.
Kevin
Davidj
07-06-2005 07:07:01
Ford 907 flail mower. I have one identical to it. Good for short stuff, Will bind up and plug on tall stuff. Good machine if you have a big lawn.
TomHath
07-06-2005 05:30:30
I used to have a mower like that. It's good for rough spots where there are weeds, small trees (up to about an inch), branches, small stumps, etc. If you go over it with that mower, it will be mowed...
Calif. Farmall
07-06-2005 04:44:00
Great mower! Next place to the south has one and it works super! Don't know much about them but it mows very smooth and his place looks like a golf coarse now.
BradB
07-06-2005 03:41:49
looks like a Mott mower. A flail mower with a single horizontal shaft that has knives on it. They are for cutting large areas of grass. Not too good for tall stuff and very critical shaft is in balance.
Hay Dr
07-06-2005 06:55:02
 Re: What is this and what does it do? in reply to BradB, 07-06-2005 03:41:49
I believe BradB is correct this looks like a Mott flail mower. Parts are available through a Alamo industrial dealer.
daddyj
07-05-2005 20:16:40
From the picture it looks like a flail mower. I don't think it is a tiller because it is belt driven. Probably has a spinning shaft inside with fingers or blades attached to short chains on the shaft.
