How to Remove Stumpjumper from Rotary Cutter
Larry Hardesty
07-05-2005 08:33:22
The bolts holding on the gear housing for my Big Bee rotary cutter have vibrated loose, and I need to replace them. To replace them it looks like I need to remove the stumpjumper. I removed the nut holding it on and reversed it to tap on it to loosen the stumpjumper from the tapered shaft. I ended up damaging the threads of the nut (fortunatley found a local machine shop to rethread it)---with more than a tap!! Still the stumpjumper will not come off. I have hammered, pried, cussed, etc. and no luck so far. Any advise welcome!!
