Holy Cow Bat Man. Tire blow out!!!
Kelly C
07-04-2005 06:03:29
third party image
I think I learned a lesson about using Radial car tires on the back of my hay racks. This made for a fun trip home from the hay field. Of course the spare that I took did not fit the hub. Got home ok just had to nurse her real slow. They seem to work ok on the front of the rack but there is allot more weight on the rear.
third party image
Purchased 2 new implement tires for the rear. Just a note for you guys buying running gear for hay racks.
Shy away from the 14 inch rims if you can. These 14 inch tires cost about $60 each. If they had been 15 inch rims the tire are about $20 less each.
Don-Wi
07-04-2005 20:37:07
 Re: Holy Cow Bat Man. Tire blow out!!! in reply to Kelly C, 07-04-2005 06:03:29
third party image
That sort of thing happens on occassion, but we've been running car/truck tires on our hay wagons since before I was born. Just because the tire says it's weight limit is 1500 lbs, that don't stop us. We try to use light truck tires, but if we don't have any around, we use whatever else we have. One brand we try to stay away from is Uniroyal. My dad used to be in the tire biz and the most problems were related to that brand. As far as our tire supply, they come off of my truck, an '88 F150 w/ 235-75/R15. The 16' we try to get old take-offs from work trucks, something like a 7.50-16 truck tire or 235-85/R16. We don't have any 14" rims around, we went to the junk yard and got 15's. You'll find plenty of 5-bolt 15 inch rims there. The only things that we use implement tires on is our chopper, baler, forage wagons, haybine and grain drill.
Donovan from Wisconsin
Leland
07-04-2005 18:47:00
We used them all the time on racks and only 1 would blow once in a while , the one pictured looked like it has bad belts since it still held air this could happen with any used tire
Bob T.
07-04-2005 10:27:36
I just put new 10 ply trailer tires on my best hay rack, not cheap but I know for a fact they can handle the extreme weight. And, being 10 ply they should be more resistant to thorns than the relatively thin implement tires. I had a blow out last year on a car tire on a hayrack and will eventually switch all to these.
j cook (iowa)
07-04-2005 06:53:42
I bought a supposedly 6 ton gear (Electric Wheel) several years ago. It had 14" tims. I replaced the really poor tires with good used radial car tires.
They had a weight rating og some 1650# each, reducing the load capacity of the hay wagon from six to a bit over three tons (6600lb).
The 11L-15 implement tires and rims now installed are MUCH better.
RickL
07-04-2005 06:26:00
Kelly C; Are you getting rich yet!!!!. No they are not design for that weight. Use tires off of 3/4 to n pickups if you going that route. Or run trailer tires period. The implement tires you showing I don't use do to faster travel speeds. You can blow them also if you travel much over twenty five due to heat build up,new or used. Been ther done that. Course I don't use wagons. I would switch the rims to 15" period. You can get new ones for 35.00
Kelly C
07-04-2005 06:39:33
 Re: Holy Cow Bat Man. Tire blow out!!! in reply to RickL, 07-04-2005 06:26:00
Get kind of stuck with the 5 hole rims. Could find 15 inch 6 hole rims. No one had 5 hole 15 inch rims.
"Are you getting rich yet!!!!. " No but thats not the point any way. If I wanted to get rich I would for sure do some thing else. But If I make enough for a nice Farmall 656 hydro, that would be nice.
Rexalot
07-05-2005 08:09:42
 Re: Holy Cow Bat Man. Tire blow out!!! in reply to Kelly C, 07-04-2005 06:39:33
Atleast your tire didn"t blow out!
I borrowed a wagon this past weekend to haul about 40 bales of straw that we took off the thresher pile (used my NH 68) since my wagon was already full with what we baled off the field. The wagon has all new wood and paint.
I didn"t know that that all the tires on it were of the "Maypop" and "Willpop" brands.
I was pulling both wagons behind the pickup with the "borrowed" wagon in the rear. I never heard or saw anything until I got to the barn and parked. First thing we noticed is that the rear wagon looked rather empty.. then noticed that the rear right tire was blown out. Luckily, we lost the the load not far from the barn, and it all fell on the side of the road not in it.
I"m doing the right thing and replacing the tube/tire even though it would"ve blown out on the wagons owner without a doubt. (40 bales of straw could"nt have weighed that much)I"m in it for the cost of a tube as I was just going to install another used 14" tire on it.
Oh, and my NH68 baler didn"t miss a knot in 180 bales. We did get a few bales that had the potential to become banana"s when we were in light material, but none ever did.
Leroy
07-04-2005 07:42:34
That 5 hole 15" rim is more popular than the 6 hole rims and the 5 lug rim from a 4 wheel drive Ford pickup will fit
Ken Macfarlane
07-04-2005 08:33:15
 Re: Holy Cow Bat Man. Tire blow out!!! in reply to Leroy, 07-04-2005 07:42:34
5 hole for a 4wd ford is 5 on 5.5" (same as some dodge, suzuki, some older jeeps etc)
6 hole implement is 6 on 5.5" (same as toyota 4wd, chev 4wd, nissan 4wd etc)
