steve nh
farmallbee
07-03-2005 17:53:42
I need to replace a bearing in a 630 roll baler. The operators manual says the part is the pivot roller-but the service manual(that I need to order) has no such item listed. It looks like it is either an apron roller or a sledge roller. In essence which repair manual should I order thanks
RickB
07-04-2005 04:00:19
 630 baler in reply to farmallbee, 07-03-2005 17:53:42
The pivot roll is part of the sledge roll group. It is the lowest sledge roll, attached to the sledge frame at the pivot. 40063040 is the p/n for the complete "0" series baler repair manual (630, 640, 650, 660) and runs about $150. 40063009 is the sledge roll section and runs about 10 bucks. Picking 3 or 4 sections will get you most info you will need for a 630 for less than the full book which has about 4 sections that don't apply to a 630 and a couple more that you are unlikely to ever open.
farmallbee
07-04-2005 09:58:38
 Re: 630 baler in reply to RickB, 07-04-2005 04:00:19
thanks a million-you saved me about 400 dollars-if I can get the manual and repair myself. You seem to be knowledgeable-can a person with some mechanic skills replace these?
Thanks again
RickB
07-04-2005 12:57:25
 Re: 630 baler in reply to farmallbee, 07-04-2005 09:58:38
I haven't yet had to change pivot roll bearings or remove the sledge frame from a baler. I have had a couple upper dimple rolls out and changed the idler gears and bearings. Mostly on 640/644's. Plan on having some help and a hoist/cherry picker if you tackle it yourself. I doubt you will need anything else beyond a good supply of common tools.
