All Crop 60 Combine belt
Dick Davis
07-03-2005 12:16:59
Can anybody supply me with the NAPA number for the long drive belt on the back of an All Crop 60 Combine? The AGCO # is: 70502435. Can't keep the blame belt on and last time it came off it was eaten by the spring loaded slip clutch!!T hanks for any help Dick Davis
msb
07-03-2005 17:27:01
 Re: All Crop 60 Combine belt in reply to Dick Davis, 07-03-2005 12:16:59
Call in or take the AGCO number to your nearest Deere dealer.They have a very good cross reference program and might even be able to supply you with a belt.If not see if they can come up with a NAPA number.
Leroy
07-03-2005 13:39:07
take a 1/2 inch rope and lay in all the pullys as the belt did and draw it tight, set the tightner in the middle, and mark the measurement and that is what you need to go by, the number of inches it measures but also measure the width of the old belt, if memory serves me correct it was a 5/8" wide belt, if they do not have that exact length and they probably will not then you can try one way or the other, other way is to set tigtner in tight and measure then repeat in loose setting and try to get in between, if not then you will just have to reposition the tightner and it can be done with work
