Update ; NH Knotter trouble
Paul W
07-03-2005 05:44:22
I found out that the bales were loose and bannana shaped because I had not adjusted the bale tension properly, rookie mistake I guess. Now the bales are nice and not sloppy , but it still misses a bale every 10 to 15 and only on one side. Most times there is a knot in the one end , I can't remember which end , and sometimes there is just two ends flattened and no knot. The bill hook on that side looks old rusted . I tried to smooth with emery cloth and it is better but I wonder if I should just replace it? Any ideas would be great. Thanks Paul
Paul W
07-03-2005 13:58:10
 Re: Update ; NH Knotter trouble in reply to Paul W, 07-03-2005 05:44:22
I was just looking at the baler again , scratching my head, and found both upper hay dog springs broke. I had one spare so put it on the side that missed alot. Hope to get a new one for the other side before baling tommorrow but will see. I will update again tommorrow. Paul
Paul W
07-04-2005 14:06:53
 Re: Update ; NH Knotter trouble in reply to Paul W, 07-03-2005 13:58:10
I could not get a new spring before baling today so had to run with only one top spring and only missed 3 bales out of 60 - 70. Much better. But the knotter brake was wore out and we broke a shear pin, fixed that and found bolts for wade board chain to plunger chain broke. Had to wire together to get the hay in before rain. I think we are finally getting a handle on this baler, I hope. Paul
max adams
07-03-2005 08:16:06
Paul, i don't know if this will help. But on mine, it would do the same thing (drove me nut's) anyway after reading the manual several times. For starters the wood bearings for the plunger needed replaced, so i did. then i filed and polished the bill hooks as the manual said. checked,cleaned,greased notter assembly. Not gresing them to much. But the plunger wood bearings did the most. But what i found on the 66 is this, it does not like big wind rows, it does not like being crowded...at all! keep notters clean, when the chaff builds up thats when they seem to start screwing up. i was told to keep oil on the knotter assembly. But i found that this made a mess of things. When i keep them cleaned, greased with in reason and run slow she does not miss a bale. Now i don't bale on a large scale, i only do 20 acres and when i do my baler like i told you she don't miss a bale. Again this works for me. This is my second season and i'm not an expert by no means, just a hobby. I love my old 66 now that i've started to figure the old girl out. After all not bad for being 50 or so years old! hope this will help?
