small round baler info
mikeyinmo
06-30-2005 09:35:16
I need info on so called small round balers. What models are they, when made, how much tractor do you need to run one properly. Will be cutting hay on a small farm soon(about 80 acres of pasture), and the last time I did any hay work it was all square bales. any help and info will be greatly appreciated. thanks in advance
HillBilly in Vegas
07-01-2005 10:01:49
 Re: small round baler info in reply to mikeyinmo, 06-30-2005 09:35:16
third party image
Sorry, posted the wrong link.
HilBilly in Vegas
07-01-2005 09:56:54
third party image
We bought a Vermeer Rebel 5400 last year, and it makes a nice 4'x5' roll. It calls for something like 40 hp to run, but we use a JD 730 diesel with it just for the extra tractor weight when rolling on hills.
haybud
06-30-2005 19:17:11
I use a case int. 8420, 40"/48"roll with a l4310 kubota.I can make 12-15 bales an hour not real fast but it does a good bale,500-600#.A good mower to use is a ccm 165 drum mower,you can mowe as fast as the ground will allow you to travel,it works great.
JMS/MN
06-30-2005 15:01:28
AC Rotobalers had an engine option, but most were pto powered. Dad used his for years with a WC, but really appreciated the live pto on the WD45, since it is necessary to stop forward motion each time you need to wrap a bale.
Steve (Magnolia, TX)
06-30-2005 13:19:54
How small?
The old Allis-Chalmers Roto-Balers made round bales.... They quit making them sometime around 1960... (I think)
Steve
06-30-2005 13:19:34
How small?
Steve
farmallbee
06-30-2005 13:03:13
new hollands are 845
848
630
634
638
730 Hesston 530, 540
JD makes some I am not familiar with
vermeer has a 504 and the new 5400 all listed will work with a 45 hp pto
Hay Dr
06-30-2005 21:16:44
 Re: small round baler info in reply to farmallbee, 06-30-2005 13:03:13
third party image
We have customers baling with Rebel 5400 balers using 3600 Fords, 3910 Fords,& 240 MF.
dorset sheep farmer
06-30-2005 09:52:41
I have a Vermeer 403F, which makes a 3 ft wide- 4 foot tall round bale. These are no longer made, but are a well built machine. Certainly it would work well behind 40 -60 hp range tractors. I like the smaller bale, since I can roll the bale by hand if necessary. Mike
