PTO shaft spec's
Tom S. in Tn.
06-29-2005 18:28:37
I am searching for a PTO shaft for an old IHC hay mower project and need to know the dimension specifications for the different series U-Joints and shafts. ie...12N, 14N, 34N, etc...
I see 3-point specs listed at this site, but I do not know where to find PTO specs.
Thanx; Tom S. in Tn.
JMS/MN
06-30-2005 08:33:15
 Re: PTO shaft spec's in reply to Tom S. in Tn., 06-29-2005 18:28:37
All 3ph specs are at www.asae.org. That's the Am Society of Ag Engineers. I've never checked for pto specs on their site, but it might be worth a try. Or try a google search for Weasler- that is a major pto mfr.
Calif. Farmall
06-29-2005 20:34:42
Hi- I'm doing the same project and I think if your trying to get the rear joint replaced it's only available from IHC. I plan on reusing my rear joint and purchasing a front section with a newer style joint and if I have to adapt it to the rear section so be it, however it looks like I can still get the square type shaft. Email me if you find somthing differnt. Dan Calif. Farmall
Tom S. in Tn.
06-30-2005 07:03:36
 Re: PTO shaft spec's in reply to Calif. Farmall, 06-29-2005 20:34:42
I can find parts, but the problem is looking in the catalogs and talking with counter people, I have to know what "series" shaft I have. How can I find out?
My u-joint appears to be ~2.5"~ wide with 7/8" dia. cups. I have not taken it out yet.
If I could know the series; 12N, 34N etc...based on the power rating, then I might be able to avoid being scalped locally by mail ordering a part.
Tom S.
Don-Wi
06-30-2005 21:26:33
 Re: PTO shaft spec's in reply to Tom S. in Tn., 06-30-2005 07:03:36
the series deal w/ the joint itself, as there are many different sizes. I think the average is 35, but that's based on what I've seen. I can't say what your's is. Probably the easiest way to identify the series is bring it in to a dealership if possible. The square tube is all standard English sizes. The one that is 3 sided and sort of rounded, is metric. 2 completely different beasts.
Donovan from Wisconsin
