retiming a 14T JD baler help please
old
06-28-2005 09:35:38
Just put new chains on and have done every as per the book but can't seem to get it timed right. Any little tricks to doing this or do we just keep trying till we get it right. Most have had the chains on and off 10 times last night and still not as it should be, I'm close but not right yet.
Thanks
TimS
06-28-2005 12:03:57
 Re: retiming a 14T JD baler help please in reply to old, 06-28-2005 09:35:38
I went thru this last year so I feel your pain...
One thing I can recommend, replace the chains, they may have stretched enough to undo your setting of the timing.
What is the problem once you retime it?
Needles not returning to home position all the way or when they are supposed to?
If you are rolling the flywheel by hand to go thru a knotting cycle the needles don't have enough momentum to return all the way home, when operating off the pto even at idle speed they will reset right.
I found that out after I cranked ours thru a few dozen rotations and the needles would never reset, I finally just started the tractor and ran the pto at idle, flipped the lever to start the knotters and it worked like a charm...
Email me if you want to, I stuck my email on this one.
TimS
06-28-2005 12:11:38
 Re: retiming a 14T JD baler help please in reply to TimS, 06-28-2005 12:03:57
Ok I just noticed you said you put new chains on, that is a good thing.
Make sure you follow the manual step by step.
One thing to make sure of, when you are putting the knotter drive chain on, make sure that drum that comes up against the roller that drives the knotters doesn't have a gap between the inside of the drum drive "bump" and the roller before you put the chain on. To much space there will throw the timing off as well. I think I tripped the knotters then rotated that drum up against the drive roller then put the chain on to make sure I had as much of the space out as possible.
Tx Jim
06-28-2005 11:51:55
 feeder fingers in reply to old, 06-28-2005 09:35:38
old, do you have feeder fingers timed correctly? Do you have slack out of frt. chain? Email me and I will try to guide you through timing. [email protected]
old
06-28-2005 13:03:32
 Re: feeder fingers in reply to Tx Jim, 06-28-2005 11:51:55
The feeder fingers are where the problem is as far as timing. Just put new chains on that and the knotter. Yep the chain for the fingers is tight also. Have the book but this thing is about to drive me nuts.
old
06-28-2005 13:02:34
BEN in KS
06-28-2005 11:36:07
You do have a manual with the timing instructions? If not, get one or copy the appropriate pages from the dealer or someone who has one. Have you replaced any sprockets? If so, count the teeth and make absolutely sure they are identical to the ones you removed. Make a timing stick out of a 1"X1" board to hold the feeder teeth in the proper position. I sold my baler and manual or I would scan it for you. HTH Ben
BEN in KS
06-28-2005 11:34:14
old
06-28-2005 13:07:09
 Re: retiming a 14T JD baler help please in reply to BEN in KS, 06-28-2005 11:34:14
Yep got the book and also have a friend that is helping, he holds the fingers in place when I'm doing the other parts so I guess you could say I have the stick just it does talk back to me at times LOL The feeder fingers are where we have the problem we can get it timed per the book but the finders are like 23 inches instead of the 16-18 that they should be
Tx Jim
06-28-2005 14:15:21
 feeder fingers timing in reply to old, 06-28-2005 13:07:09
old,the feeder fingers are normally easier to time than the needles.Get the plungerhead face on compression stroke centered in frt.finger slot and set fingers to distance,tighten chain and done.Tx Jim
old
06-28-2005 15:00:09
 Re: feeder fingers timing in reply to Tx Jim, 06-28-2005 14:15:21
Thats what we have been trying to do but every time when just about to get done we do as the book says and recheck for the 16-18 inch meassurement of the feeder fingers and its not as it should be.
Tx Jim
06-28-2005 15:31:36
 Frt.chain in reply to old, 06-28-2005 15:00:09
old,is slack out of frt.chain(chain just to the rear of slip clutch)if pto driven? Tx Jim
old
06-28-2005 16:32:35
 Re: Frt.chain in reply to Tx Jim, 06-28-2005 15:31:36
Yep we tighten them up as we go, I know how a loose chain can cause trouble. Learned that one the hard way on a motorcycle years ago.
