275 wire baler
beb
06-27-2005 11:42:54
I was given a 275 in exchange for stud service, the problem is that the needles will not go home, they remain low enough that the flywheel shear bolt breaks. I can pull the needle carriage by hand to home and the brake will hole it there.
Joe(TX)
06-28-2005 07:38:59
 Re: 275 wire baler in reply to beb, 06-27-2005 11:42:54
Are the pins or holes worn in the linkage? The rod may need to be adjusted longer to bring the needles home. Have you checked to see if the needles are going up too high?
