New Holland baler experts!
Bkeepr
06-27-2005 04:48:51
My old NH 66 has just started to break flywheel shear bolts, and I've checked all the "common" problems and baled a few dozen bales turning the flywheel by hand to find out the problem. I can see what is happening, but don't know why.
Every few bales (no pattern) when the plunger pushes enough hay to sort of barely trip the knotter mechanism, the needles kind of "fall" a couple inches toward the bale chamber and the emergency stop trips. The needles never enter the bale chamber, but are no longer locked into place. The next plunger stroke, the knotter doesn't start to tie and the plunger hits the emergency stop.
Doesn't happen every time, but often enough that it is irritating. I'll get 1-6 bales without problem, and then it'll shear.
Any ideas of what to check? I've checked baling tension, knife alignment, and the yoke and knotter brakes. What now??
thanks,
Tom A
RickB
06-27-2005 13:55:36
 Re: New Holland baler experts! in reply to Bkeepr, 06-27-2005 04:48:51
Knotter brake is the problem.
Coloken
06-27-2005 07:44:41
Like Jim say...its the brake. The brake's job is to keep the needles from bouncing out of place.
Tx Jim
06-27-2005 05:31:02
 needle brake in reply to Bkeepr, 06-27-2005 04:48:51
Bkeepr,I'm not NH expert but this will help,tighten or replace needle brake.Tx Jim
