vermeer belts seem loose now
bigih9
06-27-2005 03:38:00
I have a 604J round baler and havent used it yet but am going to tonight after work. I bought this baler and fixed a few minor things and had it hooked to the tractor and ran the belts. Yesterday I hooked to it and opened the tailgait before turning the pto on and when I shut the tailgait the belts seem extra loose now. What happened?
Hay DR
06-27-2005 09:09:21
 Re: vermeer belts seem loose now in reply to bigih9, 06-27-2005 03:38:00
Check the pressure in the air pressure in the airbags. Sometimes the AIR Pressure gauge out front is not correct and may need replacing. For 6' bales the starting pressure need to be 80-120 PSI. You can use a truck tire pressure gauge. The start tension on a J bale is set with the 3 bolts on the front of the airbags. If you call Vermeer and ask for a manual they will send you one free of charge. 641-621-7558
paul
06-27-2005 08:27:37
That is normal for my older 605F.?
--->Paul
marlowe
06-27-2005 06:30:18
make sure it's running when you open and shut it
