To Unimog
Rich Iowa
06-26-2005 18:36:51
OK, I just saw the pictures of your setup in the implement photos section. How does your bale buncher work? I can't seem to figure out how it puts the bales in rows. Could you explain how? Thanks, Rich
RickL
06-27-2005 09:56:58
 Re: To Unimog in reply to Rich Iowa, 06-26-2005 18:36:51
RichIA; get yourself an accumulator and grapple and be done with it. Unless you have helpers the buncher still has to be picked up by someone. One you learn to use grapple you won't go back. Will be running this afternoon if want see one working. You in Iowa somewhere i take,Im in southeast corner, might be able run this afternoon.
Rich Iowa
06-27-2005 15:04:12
 Re: To Unimog in reply to RickL, 06-27-2005 09:56:58
Rick, I would love to get an accumulator, but there is no way to justify one on the 5 acres I have right now. I'm just west of Des Moines, 6 miles or so in Adel. After I get a mower conditioner, I'll be working on a better rake and bale accumulator. Rich
RickL
06-27-2005 17:00:27
 Re: To Unimog in reply to Rich Iowa, 06-27-2005 15:04:12
for the 5 acres you can't really justify much of any of it.
RickL
06-27-2005 17:00:17
ChrisLSD
06-27-2005 06:49:09
Thanks for the pictures - wasn't quite like I imagined.....
BobMo
06-26-2005 19:28:04
After reviewing the pic's I understand how it works but its easy to see that nothing is uniform as there are no controls except the gate. The advantages are limited but its better than nothing. It does not leave bales assembled for pickup with a bale (grapple) fork and the number of bale on it are at the operators discretion and probably results in numerous damaged bales. Maybe better than a stooker. I'm not sure.
Unimog
06-26-2005 18:55:51
The bales drop from the chute onto the buncher
where the bales ride on 1/2 rods spaced 8 inches
apart. Each bale slides toward the rear gate till
the buncher is full, usually around 10 bales. I
then pull a rope from the tractor which lifts a
gate lock and the weight of the bales push open the gate and the bales are in one group. The gate
rides over the bales and shuts for reset. Next
time around the field you try to dump near the
last pile. No bales are ever damaged or get dirty.
I got mine about 10 years ago and it was some of
the best money ever spent, about $450.
Rich Iowa
06-26-2005 19:07:22
 Re: To Unimog in reply to Unimog, 06-26-2005 18:55:51
so does your buncher just collect them in no specific order or pattern or does it, for lack of better words, stack the bales like an accumulator, ready for a grapple to pick them up.
gac
06-27-2005 04:49:24
 Re: To Unimog in reply to Rich Iowa, 06-26-2005 19:07:22
I have a buncher as well. It just groups the bales together. It does not arrange them for a grapple. We used it to put the bales in bunchs for stooking or loading. Elimindates walking around the field after bales.
