We had a NH haybine from 72' till around 1990 I think. It cut a lot of hay over they years. One day I borrowed my nieghbors 9ft disc mower to try out and was impressed. So we got a CIH 3309 which is a New Idea 9ft painted red. NO comparison when it comes to cutting speed. Sure the old haybine cut hay but nothing like this disc mower. Some days with the old haybine I would be on and off constantly unpluging the cutter bar. Especailly in our 2nd cut with fine wet grass in it under the alfalfa. That stuff was a pain to cut sometmies but with the disc mower its no problem. I will say though in fields where the alfalfa is laying down bad the disc mower does not clean it off as good when you travel the way its laying. The blades last a long time too. As long as your not leveling out mole hills all day!!! Thats hard on them when you smash through mounds of dirt constantly at high speed. I feel its best if you don't stick a 150hp tractor on a little 9ft disc mower etc. I use a 85-95 hp tractors on my 9ft mower and its seems about right. You can feel it when the disc mower is working hard etc. Also keep your blades sharp, its cuts way harder when you just have little chunks of metal left spinning around. Plus it doesn't make as clean as cut either with crappy blades. I have not noticed any differance in regrowth over the last 15 years. So I'd give disc mowers the "thumbs up" especailly if you have lots of acres to cover. But if your only doing a small amount then it may not be economically practical when you can find old haybines for a few hunderd bucks.
