Unfounded concerns with disc/drum mowers?
Loren
06-26-2005 13:41:52
My worry about the disc/drums is that without a "tailwheel" (for lack of a better word) would allow the outboard end to dig in when the bumps tilt the tractor that way, and cut air going the other way, leaving a horrible looking cut and possible $$$ for repairs. ??? To get a small enough length mower to eliminate this would negate most benefits of increased production. Do any of these units actually ride the ground or have a wheel to eliminate this problem? These fields are pretty rough guys.
Oh, the Case swather does have a conditioner built in. Wish I had experience with other equipment.
Thanks for the help. Loren.
alan in uk
06-26-2005 14:01:20
 Re: Unfounded concerns with disc/drum mowers? in reply to Loren, 06-26-2005 13:41:52
We have a mounted lely 8ft disk mower conditioner, (used it today!!) you can really motor on with it, it follows the ground lovely, and cuts laid crops well. i use it on a 80horse power tractor with no problems! Alan in uk
Roy in UK
06-26-2005 15:43:44
 Re: Unfounded concerns with disc/drum mowers? in reply to alan in uk, 06-26-2005 14:01:20
Had the same machine Alan on a Massey 168! not even a wisp of smoke lovely tool. Heck if its good silage/haymaking weather are you going to sit back and waste a good day?
Alan in UK
06-26-2005 23:39:35
  Wasting a day??? ... the day was over.... time di in reply to Roy in UK, 06-26-2005 15:43:44
ha ha ha, Roy, i was off to bed when i posted last night,(it was 9:30 i think) i had made use of a very nice day! lugged 36 round bales of silage for myself and mowed 7 acres of first cut silage for a customer, i'm going to be baling it today!!
The post time is different to what is printed with the post!!! the time here and now is 07:53AM I've been up since 5:00, milked 70 cows, and i've just come in for my breakfast!!
Have a good day!
Take care all
Alan in UK
Roy in UK
06-26-2005 15:43:01
buickanddeere
06-26-2005 14:55:58
 Working on the Sabbath? Re: Unfounded concerns wi in reply to alan in uk, 06-26-2005 14:01:20
alan in the uk
06-26-2005 23:46:47
 Re: Working on the Sabbath? Re: Unfounded concern in reply to buickanddeere, 06-26-2005 14:55:58
No rest for the wicked, or so they say!!!
Ken Macfarlane
06-26-2005 19:09:52
The cutterhead of the disc rides on rub plates on the ground so it follows very well, it isn't fixed to the tractor angle.
I was thinking of the production issue myself. If the fields are rough and you are already driving at your max comfort level, you need to go wider. But if the fields are extremely rough a 14 ft pull type swather is going to miss dips and hit bumps etc.
I'm not familiar with purpose built swathers as no one owns one here in the east. Everyone uses pull type equipment.
I was mowing today with a 9 ft haybine and I could only stand 4.2 mph (4 acres an hour). The fellow that cut it last year had a 12 ft wide discbine with a big JD and was hitting 12 mph in the same fields. (he also has back problems, go figure) I'm sure our mower would go faster but not with me piloting it.
I would love to set up a front mount mower conditionor and match it with a pull type or semi-mounted on the rear.
Ken
Loren
06-26-2005 22:30:57
 Re: Working on the Sabbath? Re: Unfounded concern in reply to Ken Macfarlane, 06-26-2005 19:09:52
If pretty much all the disc and drum mowers ride the ground then I'll be thinking that direction maybe. That'll be, what, $5-$6K for a decent used tractor and a used mower to match? The 300U won't handle much width judging by the hp figures I've seen in some literature.
Ken, on the front mounted and haybine thought, that's the same thing I've had in mind. Feel like getting a tractor more than big enough to handle a discbine and take the swather head with rolls off the Case and mount it up front. Maybe a hyd. drive for it.
edchainsaw
06-26-2005 19:55:21
I've run a disc mower for 25yrs now.... mowed everything you can think of.. ruts, hog wallows, yards(yes lazy renters) and ditch banks, road sides (rocks included) fence posts and all.. never spent much on the thing
it has always left a good cut even with bad knife's..
oh and I would LOVE to have one of those CLAAS machines 250hp- 30ft cut (3 sections front left and right) and condtioners --- YA ... I need that for my 100acres of hay a year!
mlm
06-27-2005 22:27:51
 Re: Working on the Sabbath? Re: Unfounded concern in reply to edchainsaw, 06-26-2005 19:55:21
What brand of disc mower did you use?. sounds very dependable.
edchainsaw
06-26-2005 19:55:04
Roy in UK
06-26-2005 22:17:08
 Re: Working on the Sabbath? Re: Unfounded concern in reply to edchainsaw, 06-26-2005 19:55:04
third party image
Do you mean this? The Claas Cougar is actually 14 metres(nearly 46 feet) wide and has a 480hp Daimler-Chrysler engine.it has been said you can knock 50 acres an hour down with it!
Hay DR
06-27-2005 06:28:45
 Bigger is not always better in reply to Roy in UK, 06-26-2005 22:17:08
For $30,000 each one can easily purchase a NEW 70 HP tractor and a 10.5' disc mower. Krone has a big cutter like the Class pictured and it lists for $360,000. For less than half the money, 5 tractors equiped with 10.5' disc mowers would at least the same amount of work as the unit pictured.
Tim(nj)
06-27-2005 07:25:35
 Re: Bigger is not always better in reply to Hay DR, 06-27-2005 06:28:45
That"s assuming you have people to run those tractors. The only use for that big SP mower I can see is a custom cutter who has one guy knocking down a bunch of grass and a crew of 10 running SP choppers and trucks behind him.
Ken Macfarlane
06-27-2005 06:19:39
 Re: Working on the Sabbath? Re: Unfounded concern in reply to Roy in UK, 06-26-2005 22:17:08
Wow. What kind of acres would you have to own to make that thing pay for itself!
Roy in UK
06-27-2005 11:54:23
 Re: Working on the Sabbath? Re: Unfounded concern in reply to Ken Macfarlane, 06-27-2005 06:19:39
third party image
It is designed for agricultural contractors really. By the way its not just a mower, each cutterbed has its own flail conditioner.
edchainsaw
06-27-2005 20:40:06
 Re: Working on the Sabbath? Re: Unfounded concern in reply to Roy in UK, 06-27-2005 11:54:23
actually I dint know they had that new model :) I only saw the smaller one.. :)
I working by myself could use that real effectively.. I cant mow enough in the morning to keep me baling very long the next day when I bale--- ( here its dry enough most of the time and hay's not good) you can mow from 7am till dews off. then you go and rake what you mowed the morning before.. and bale... I can mow for 2-3 hrs and bale up 15 or 20 bales..
