Jd 335 Baler plugs top roller with hay - adjustmen
jh from virgini
06-26-2005 08:52:28
I've had this baler about 5 years with mostly no problems. Now it wants to wrap hay around the top large roller in the tightest spot on the machine. Has anyone else had this problem w/ 335 or other make/model and have a fix? I baled about 200 bales this year without problems and about 35 since having to lace innermost belr on the right side. Used a 410 before buying this bale and thought my troubles were over.
flying V ranch
06-26-2005 17:37:59
 Re: Jd 335 Baler plugs top roller with hay - adjus in reply to jh from virginia, 06-26-2005 08:52:28
I have a JD 500 baler that has a closed throat design. I'm not sure about yours, but this is what I have discovered about mine. First bale dry hay only or the grass will wrap around the top roller. The big problem I had was that the drawbar on my tractor is nearly 16 inches from the ground. When I hitched to the baler, the pickup reel was then at too much angle to the throat rollers and grass would just ride up and start jamming. I welded a new hitch that drops down the baler tongue to the recommended 12 inches and now the pickup reel is nearly 90 deg. to the throat rollers. I can now go through coarse and stemmy grass and it just sucks it off the ground flawlessly and hasn't jammed all summer. I would suggest you get back and take a sideways look at your baler when hitched to your tractor and see the angle of the pickup reel to the rollers. Might just be your problem.
Tx Jim
06-26-2005 10:13:14
 hay running up belts???????? in reply to jh from virginia, 06-26-2005 08:52:28
jh,does hay run up belts when you start a bale? Do you run pick-up as high as possible? Are any pick-up teeth broken? Is pick-up belt adjusted to spec's? Do you know how many bales baler has baled? TX Jim
jh from virginia
06-26-2005 17:14:32
 Re: hay running up belts???????? in reply to Tx Jim, 06-26-2005 10:13:14
There is nothing running up the belts that i can see from the tractor seat and I've made a concious effort to keep the pickup (which had all new teeth when I bought it) up pretty high to reduce wear on the teeth. By all accounts I don't think the baler is worn out but i don't know how many bales it has baled total - 1600-1800 since 2001. I have noticed what sounds like a bent pickup tooth that i haven't got around to fixing.
Tx Jim
06-27-2005 03:42:31
 Re: hay running up belts???????? in reply to jh from virginia, 06-26-2005 17:14:32
jh,on Deere balers that i've been around when bermuda hay gets a little dry it can run up belts in frt. and lodge.It usually is worse right at core formation.Are you having any problems getting bale started?Tx Jim
