mounted cultivator off M
RickL
06-26-2005 04:46:05
antoher cultivator got dropped off here that was on M anyone have any interest otherwise will go to buddy who crushes items. Looks pretty complete,wopuld like to find interestd party to salvage it
David A. Hodson
06-26-2005 12:05:39
 Re: mounted cultivator off M in reply to RickL, 06-26-2005 04:46:05
Hello Rick do you ever get any plow dropped off to you I've been looking for a plow(s) for my 400 and H Thanks In Advance David
RickL
06-27-2005 05:50:41
 Re: mounted cultivator off M in reply to David A. Hodson, 06-26-2005 12:05:39
Yes, Currently I have a Little genius 3btm,can be made into two, pulltype, rubber tires. Is complete and looks usable with not much effort. It probably would need tires thou. Have JD unit on steel and Have about four other units that have not showed up yet. have two 3pt units also. tell me what you are looking for will let you know shape and price or if now where unit is if i don't have. They have been ranging from $50.00 to $350.00
JiminIA
06-26-2005 05:41:16
Rick, I may be interested. Send me an email with what you want for it. I think you are pretty close to me.Is it for farmall M?...Jim
RickL
06-26-2005 06:59:24
 Re: mounted cultivator off M in reply to JiminIA, 06-26-2005 05:41:16
$50.00 would that work I just want it gone to someone really hate destroying this kind stuff
RickL
06-26-2005 06:57:47
thats what I was told it came off is all I know 2row
RickL
06-26-2005 06:57:29
max in ohio
06-26-2005 05:32:49
Is this for a IH or JD? and where are located?
RickL
06-26-2005 07:01:33
 Re: mounted cultivator off M in reply to max in ohio, 06-26-2005 05:32:49
All Iknow was told it was off M farmall,don't know if it would do a H also. $50.00
Delbert from Lincoln
06-26-2005 07:39:41
 Re: mounted cultivator off M in reply to RickL, 06-26-2005 07:01:33
That cultivator will fit either a H or M. It is probably a 238 H-M. would also fit a F-20 F-30 by welding some small pieces on it to fit those front horns on the frame. I can"t explain that one, but anyone who has seen the front of the frame on a F-20 will understand.
RickL
06-26-2005 09:03:01
 Re: mounted cultivator off M in reply to Delbert from Lincoln, 06-26-2005 07:39:41
Thank you for the additional information. RickL
