Vermeer 504G
LDA in GA
06-25-2005 13:12:40
I have a 504G, which has suddenly begun burying the twine deep in the bales. Anyone have any advise...please!!
Vapet
06-26-2005 05:54:51
 Re: Vermeer 504G in reply to LDA in GA, 06-25-2005 13:12:40
Check the flat head bolt that the upper end of twine tube comes to rest on. This and the knife cuts the twine. Does twine tube drift down while baling? I have always sharpen knife as sharp as possible and adjust the flat head bolt to stop twine firmly. May have groove worn in flat headed bolt.
KEH
06-25-2005 18:54:13
It's possible the twine not being cut at the end of the bale, but you probably would have seen that. Its more likely the hydraulic twine arm is dropping down on its own and feeding the twine in. Check the catches when the twine arm is brought back up. Twine arm MIGHT be bent at pivot point. Pivot point may be worn so that there is enough play in it to let the arm drop down. The F model I had would not cut the twine well, so I made a knife from an old mower knife section that was about an eighth of an inch higher. Worked fine then. Good Luck. KEH
Roy in UK
06-25-2005 14:54:09
The only 2 round balers I know much about are the Claas 62 and the John Deere 550, so I am not really qualified to comment as such on your baler but logically speaking I would say the twine is being picked up far to early. Could it be that for some reason the twine arm is going across the bale "on its own"? is it electric, manual or hydraulic tie?
LDA in GA
06-25-2005 15:06:39
 Re: Vermeer 504G in reply to Roy in UK, 06-25-2005 14:54:09
The 504G is hydraulic tie.
