Bob replied: Paul, I hope your system included the reservoir because as you are aware this is an open system. Being open (atmospheric) is what allows it to bleed its self. Good luck and enjoy... ----- ----- ----- ----- ----- ----- ----- ----- Bob, I did the adapter plate mod and am using the internal hydraulics. I have a pressure side line coming off the right side test port. It goes to my open center control valve. Returns to the modified adapter plate. I tested the remote hydraulic system with it completely set-up. (But, the loader isn"t attached to the cylinders yet.) My 3 pt. lift arms work as well as ever. The loader hydraulic cylinders that had sat for many years took a little time but they eventually popped free and extended. I"m guessing that the delay in extension could have been due to the system working the air out first. It also could be due to the rams sticking from the years of inactivity. Nonetheless, I"ll add the loader tomorrow and do multiple raise/lower cycles and see if I can get the cylinders to operate more easily. Thanks to all for the help. Paul.
