vermeer bearing interchange
mlm
06-24-2005 01:47:45
i have a vermeer 605c. Is there a sub for a 1 1/4 bearing # ug22unl and vermeer # 17325001. This fits in a pillow block flange. Vermeer wants $47
Have been unable to cross it over to a fabnir ,BCA or other.
Sid
06-24-2005 17:33:38
 Re: vermeer bearing interchange in reply to mlm, 06-24-2005 01:47:45
You said it won't cross refrence with Napa or Carquest. My most favorite Napa man has retired. He would take the bearing mesurments and find me a bearing or bearings or U joints or whatever he didn't need no stinking cross refrence he would call and find it. Carquest around hear is good about taking measurements and finding stuff for me.
mlm
06-24-2005 08:45:13
The number ug22unl is the number on the Link-Belt brand bearing itself. It won't cross at NAPA and Carquest
CJ-maybe
06-24-2005 12:38:42
 Re: vermeer bearing interchange in reply to mlm, 06-24-2005 08:45:13
Didn't recognize that #,thats why said look at race,sorry about that.Not familiar w/ link belt #'s,but looks goofy,not even close to what I found.Might be best to take it to a bearing supplier, see what they say.If not just the bearing,maybe change housing & all to something more available,just a thought.Let us know what you find.
CJ-maybe
06-24-2005 05:59:05
Should be manuf name and # on the edge of the race.Maybe hard to read or messed up.An industrial or bearing supply can tell you who made it & what will fit.Take it w/ you,they should be able to match it up.
Joe(TX)
06-24-2005 04:52:19
Are the bearings the ones with the radiused outer race and the locking collar? They are standard. I buy my bearings at an industrial bearing supply. The ones on my MF(Vermeer) are standard bearings, although mine only has 1 3/8 and 1 1/2 in sizes.
I don't have the numbers at hand right now. What brand is the bearing you have? I don't recognize the number. Any bearing house has an interchange book.
Allan in NE
06-24-2005 03:38:21
MLM,
Did you take the old bearing into NAPA or Car Quest? They might be able to cross it for you.
I just went thru the same thing on my old John Deere grain drill. JD wanted $17.60 and the same part thru the auto stores was $6.80 and a better quality bearing too.
Might be worth at try,
Allan
TimS
06-24-2005 08:13:57
 Re: vermeer bearing interchange in reply to Allan in NE, 06-24-2005 03:38:21
Or try a bearing wholesaler in your area, if you have a part number they very well may be able to cross reference it for you and get you a bearing quicker and cheaper. One hear in kansas city has gotten me a couple bearings that jd was out of stock on and wanted twice as much for.
