I like them too. Buy a bucket full of plates for large seeds. It is easier and faster to change the plates than the sprockets. Once you decide that you like them, you can get 36 and 72 hole plates for small seeds. JD parts can be expensive, so if you have a chance to buy a third unit, I'd buy it even if it is a little beat up. If extra units are really cheap, buy several and leave your Planet Jrs in the shed. Extra hoppers would be nice. Ones from 494 will work, 290s will not. I have a set of short, large diameter hoppers that make it easy to see what is going on from the tractor seat. I'm thinking that a little Bondo around the outside edge might make them fill the plates for vegetables better. There are several kinds of hoppers. Beet hoppers work better for small seeds. They have a loose n=metal filler plate under the seed plate. The corn / bean hoppers will work better for large seeds. The seed plate in those runs directly on the hinged floor. Otherwise, it is just the basics. See that all the parts are there and anything that should move actually does. See that the spindles have been greased and aren't all loose. I can't imagine that the bevel gears could ever wear out. The shoulders on the carriage bolts that hold the packing wheel / adjust the chain are are always rounded off. Getting enough rain and warm weather ? Greg
